reinstalled my windows 16.1 used latest usb image installer
Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
nvidia 1080 in use
ASUSTeK COMPUTER INC. Z170 PRO GAMING bios 2003 and 3016
64-bit Windows 10 (10.0.14393) samsung 850 evo 500gb EFI system partition. did not have this in my old install.did this bios on Version 1904.
all my system. are these right drivers?windows update says it failed to install Intel - Other hardware - Intel(R) 100 Series/C230 Series Chipset Family SMBus - A123-Intel - Other hardware - Intel(R) Management Engine Interface - Intel driver update for Intel(R) Ethernet Connection (2) I219-V.
after that i installed asus drivers,but nothing seems not to update.all done in admin.
Intel(R) 100 Series/C230 Series Chipset Family LPC Controller (Z170) - A145 version 10.1.1.38 3.10.2016
Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port # 1 - A110 version 10.1.1.38 3.10.2016
Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port # 9 - A118 version 10.1.1.38 3.10.2016
Intel(R) 100 Series/C230 Series Chipset Family PCI Root Port # 17 - A167 version 10.1.1.38 3.10.2016
Intel(R) 100 Series/C230 Series Chipset Family PMC - A121 version 10.1.1.38 3.10.2016 says not needed or installed, but no yellow bangs
Intel(R) 100 Series/C230 Series Chipset Family SMBus - A123 version 10.1.1.38 3.10.2016 says not needed or installed, but no yellow bangs
Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Host Bridge/DRAM Registers - 191F version 10.1.1.38 3.10.2016
Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x8) - 1905 version 10.1.1.38 3.10.2016
Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901 version 10.1.1.38 3.10.2016
installed all asus site new drivers.
intel update tool will not work Z170 PRO GAMING finds nothing.
installed intel inf
so do i manually remove every driver or what?
Device ACPI\GenuineIntel_-_Intel64_Family_6_Model_94_-_Intel(R)_Core(TM)_i7-6700K_CPU_@_4.00GHz\_1 was configured.
Driver Name: cpu.inf
Class Guid: {50127DC3-0F36-415E-A6CC-4CB3BE910B65}
Driver Date: 04/21/2009
Driver Version: 10.0.14393.0
Driver Provider: Microsoft
Driver Section: IntelPPM_Inst.NT
Driver Rank: 0xFF0004
Matching Device Id: ACPI\GenuineIntel_-_Intel64
Outranked Drivers: cpu.inf:ACPI\Processor:00FF2000
Device Updated: false
Parent Device: ACPI_HAL\PNP0C08\0
Device PCI\VEN_8086&DEV_A123&SUBSYS_86941043&REV_31\3&11583659&0&FC was configured.
Driver Name: oem12.inf
Class Guid: {4D36E97D-E325-11CE-BFC1-08002BE10318}
Driver Date: 10/03/2016
Driver Version: 10.1.1.38
Driver Provider: INTEL
Driver Section: Needs_NO_DRV
Driver Rank: 0xFF2001
Matching Device Id: PCI\VEN_8086&DEV_A123
Outranked Drivers: oem2.inf:PCI\VEN_8086&DEV_A123:00FF2001
Device Updated: true
Parent Device: ACPI\PNP0A08\0
Device PCI\VEN_8086&DEV_A121&SUBSYS_86941043&REV_31\3&11583659&0&FA was configured.
Matching Device Id: PCI\VEN_8086&DEV_A121
Outranked Drivers: oem2.inf:PCI\VEN_8086&DEV_A121:00FF2001
Your computer seems to identify proper drivers in device manager.
If you would like to update to the latest version, try this link for version 10.1.1.42
https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility-?product=46644 https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility-?product=46644
Since you already have appropriate drivers installed, you may need to install through -overall command.
Allan.
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
