Hello
The specs state Max Memory Size (dependent on memory type) is 2GB. What does this mean exactly? Can I get 4GB? If so, How?
Thanks All
Hello; Dependant on memory type means that you can install up to 2gb of memory as long the memory type is DDR2-667. This means that you can install either 2 memory sticks of 1 GB each or 1 stick of 2gb and the processor will support them as long they are DDR2-667 Unfortunately the processor won't support 4 4gb of memory.
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
Topic Options
