Processors
14874 Discussions
BIOS Reset for Intel NUC
BOOK3R
Hi, we have an Intel NUC D54250WYKH & we accidentally disabled all the USB ports when in the BIOS. When we restarted the NUC, our USB keyboard is no longer detected and we cannot get back into the BIOS or boot to the OS or external media/devices.
We tried the following to clear the BIOS:
1. removed the jumper pin
2. removed the battery
3. reinstalled the BIOS
4. installed an older BIOS
Unfortunately, none of the methods we tried have not worked.
Is there another way to clear/reset the BIOS so that we can access the Intel NUC once more? Is there manual way to short PINs on the motherboard or another program we can use to reset the BIOS?
Any info would be appreciated...
LeonWaksman
  1. Try to enter Power Button Menu: press Power Button for about 3 seconds. You should release the Power Button soon as the power led changes color from blue to amber.  Alternately, the system will emit three short beeps from the PC speaker or headphones, if connected, then stop. While you see the LED color change or you hear the beeps, release the Power Button - NUC shall reboot into Power Button Menu. You should release the Power Button before 4-sec shut down override.
  2. While you see the Power Button Menu, press F3 to disable the Fast Boot and press F2 to enter BIOS.
Leon
n_scott_pearson
Move the jumper from pins 1-2 to pins 2-3 and then power on.
BOOK3R
Thx for your reply. Unfortunately, we also tried the moving of the jumper pin to pins 2-3 and also with no jumper pins at all but that only stated that it has cleared the admin password. When the system reboots, we still cannot access any of the USB ports and thus cannot use F2 to access the BIOS.
LeonWaksman
Leon
BOOK3R
Success!
Got it on the 3rd try but was able to use the Power Button method to access the BIOS by holding the power button for about 3 seconds and then hitting F3 and then F2.
You rock sir! (Bill & Ted's air guitar riff sound)
