My 6700k cpu with everything at stock idles at over 1.4v and temp is above 60c. I have set balanced power plan. I first thought it was the cpu cooler, a H110i. So it got that replaced but it changed nothing. I also get low scores on cinebench r15, 833 at max. When i stresstest the cpu with intel extreme utility it does not say it is throtteling. i once got a bluescreen. Is it broken? Do i need to rma it? I am running windows 10 pro 64bit.
Hello Ahasvold,
I would like to verify some information in regard to your system in order to confirm if this can be considered as normal behavior, so please provide me with the following reports;
- Intel® Processor Diagnostic Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Download Intel® Processor Diagnostic Tool
- Intel® System Support Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
- What tool are you using to check those temperatures? Can you attach a screenshot of those temps?
- What tasks were you running when the bluescreen happened?
I must say that the temperatures you are reporting seem fine; however, I would like to confirm that with information requested above.
Amy.
Hello. Thank you for your answer.
*Downloaded the tools and it passed the test.
*I am using HWmonitor, latest edition.
* I was running Cinebench R15 when bluescreen appeared. But that was a one time only.
Can there be a windows setting? Faulty motherboard? Or just a bad chip?
In order to respond to your questions, please attach the report and add the screenshot of the HWmonitor.
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Amy.
/thread/106744 Ahasvold,
Were you able to follow the suggestion mentioned above? If the issue persists, attach the information requested in post # 1.
Amy.
Hi!
I tried all the suggested above. But it was the same.
So i did a clean install og windows and everything is back to normal now
Thank you
I am glad to hear that you were able to fix it.
If you need further assistance let us know.
Amy.
Did you try and reset everything to default in Bios?
wingman99, thank you for the suggestion.
/thread/106744 Ahasvold, try that suggestion and let us know how it goes.
Amy.
