Processors
14587 Discussions
CPU Upgrade
I want to upgrade current CPU (Intel Core 2 Duo E6320 @ 1.86 MHz, Socket 775 LGA, Bus Speed 266.7, rated FSB 1066.7. Motherboard Intel # D945GCF.
I want the fastest CPU that's compatible. Would upgrade motherboard, but computer is loaded with costly software.
Can someone tell me the Fastest compatible CPU?
Hi Jack,
Unfortunately, I cannot find any board D945GCF from the Intel Website. Is this an OEM board?
All the Boxed NON-OEM Intel Boards with Chipset 945 are :
/support/motherboards/desktop/D945GBO Intel® Desktop Board D945GBO /support/motherboards/desktop/d945gclf Intel® Desktop Board D945GCLF /support/motherboards/desktop/d945gclf2 Intel® Desktop Board D945GCLF2 /support/motherboards/desktop/d945gcnl Intel® Desktop Board D945GCNL /support/motherboards/desktop/d945gcpe Intel® Desktop Board D945GCPE /support/motherboards/desktop/D945GPM Intel® Desktop Board D945GPM /support/motherboards/desktop/D945GRW Intel® Desktop Board D945GRW /support/motherboards/desktop/d945gsejt Intel® Desktop Board D945GSEJT /support/motherboards/desktop/d945pdk Intel® Desktop Board D945PDK /support/motherboards/desktop/d945plnm Intel® Desktop Board D945PLNM /support/motherboards/desktop/D945PLRN Intel® Desktop Board D945PLRN /support/motherboards/desktop/D945PSN Intel® Desktop Board D945PSN /support/motherboards/desktop/D945PVS Intel® Desktop Board D945PVS /support/motherboards/desktop/D945PWM Intel® Desktop Board D945PWM
Note: you will find all the cpu compatible with the board, and the speed of the cpu from the compatibility list
Make sure to update the bios to the latest one as some CPUs need to have a certain bios revision to be able to work properly.
Otherwise, if your board is OEM, you will need to check with the OEM Manufacturer.
All the best,
Aryan
Thanks, Aryan. The mobo is indeed D945GCF, according to CPUID software. Computer is Gateway GM5446 E.
