Processors
14664 Discussions
CPU frequency reset / Сброс частоты процессора
ДШапо
Google translator
The processor https://ark.intel.com/products/75459/Intel-Core-i5-4200U-Processor-3M-Cache-up-to-2_60-GHz Intel® Core™ i5-4200U Processor (3M Cache, up to 2.60 GHz) Product Specifications in the laptop Dell ins 3537. No load in idle 2.29GHz to 2.48GHz. Under load, the reset to 2.29GHz. Three years ago the frequency at the load was 2.59 GHz. Bios updated, driver updated. Windows new
Процессор https://ark.intel.com/products/75459/Intel-Core-i5-4200U-Processor-3M-Cache-up-to-2_60-GHz Intel® Core™ i5-4200U Processor (3M Cache, up to 2.60 GHz) Product Specifications в ноутбуке Dell ins 3537. В простое частота скачет от 2.29ГГц до 2.48ГГц. Но если запустить тяжелую программу или игру частота сбрасывается до 2.29ГГц. Но года 3 назад частота при нагрузке была 2.59ГГц. Биос обновил, драйвера обновил. Виндовс новая.
ДШапо
Windows 10 . AMD radeon 8600hd
Hello, dimidrolrus.
Thank you very much for taking the time to reach the Intel® Communities Team.
Can you please make sure the Intel® Turbo Boost Technology is enabled in your BIOS? If it is enabled already or you do not have this option on your system you can set the BIOS Settings back to default.
Please bear in mind that the processor will change the frequency as it requires to depending on the tasks that are running at the moment so the processor does not necessarily need to be at its maximum frequency, it will reach it when it requires to.
Please share with us the results.
Antony S.
ДШапо
Yes turbobust included. That's what I found on the Internet. "Both cores operate at a base frequency of 1.6 GHz, but can automatically be accelerated using Turbo Boost technology to 2.3 GHz (2 active cores) or 2.6 GHz (1 active core)." Will you confirm this?
Thank you for your reply dimidrolrus.
Indeed the functionality of the Intel® Turbo Boost Technology 2.0 will be to change the frequency of the processor depending on the workload.
Please let me know if you were able to set the BIOS settings back to default and the results.
Antony S.
ДШапо
После сброса BIOS частота процессора в 3D-графике составляет всего 2,29 ГГц, в нормальном состоянии без нагрузки 2,30 ГГц - 2,52. В среднем 2,4 ГГц.
That is, my processor will not be able to accelerate to 2.6 GHz in Turbo Boost technology?
But I repeat that when the CPU frequency was stable at 2.59 GHz
I really appreciate that information, /thread/123237 dimidrolrus.
I would like you to run the https://downloadcenter.intel.com/downloads/eula/19792/Intel-Processor-Diagnostic-Tool?httpDown=https://downloadmirror.intel.com/19792/eng/IPDT_Installer_4.1.0.24.exe Intel® Processor Diagnostic tool to verify if there is any hardware issue, please share with us the results. Furthermore, let me add that the processor does not necessarily require to maintain its frequency up to 2.59Ghz, it will increase or decrease the frequency as it requires to.
Antony S.
Hello, dimidrolrus.
I would like to double check if you were able to run the Intel® Processor Diagnostic Tool and the results.
Antony S.
ДШапо
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - IMC - Pass.
CPU 1 - Prime Number - Pass.
CPU 1 - Floating Point - Pass.
CPU 1 - Math - Pass.
CPU 1 - GPUStressW - Pass.
CPU 1 - CPULoad - Pass.
CPU 1 - CPUFreq - Pass.
CPU 1 - IGD - Pass.
CPU 1 - PCH - Pass.
CPU 1 - SPBC - Pass.
IPDT64 Passed
--- IPDT64 - Revision: 4.1.0.24
--- IPDT64 - End Time: 20.03.2018 15:27:04
PASS
Thank you very much for your reply and the results of the Intel® Processor Diagnostic Tool, dimidrlrus.
By checking the results, it seems that the processor is healthy. At this point, I would highly recommend you to get in touch with the manufacturer of your system to double check with them this behavior.
Antony S.
