Processors
16290 Discussions
Can I install an SSD NVME ?
rodriguez69
Good Morning
I want to install an SSD with NVMe specification. The manufacturer (Acer) does not want to give me the technical manual, so I don't know if my equipment supports it. In the linux terminal I used lspci | grep "PCI" and returned:
PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port,
Does this mean that it supports the NVMe specification?
Thank you
n_scott_pearson
If your motherboard provides a M.2 Type M connector, then you can install a NVMe SSD. This ~should~ be the case, as NVMe was supported in the 100 Series chipsets, but it isn't guaranteed.
