Processors
14589 Discussions
Can not install intel processor identification utility
Husneara
Hi everyone!
I am facing a problem with installing the intel processor identification utility. shows error code: 2417213376. Please help me to solve this issue.
AlHill
What is the processor model number?
Provide the link from where you are downloading the utility.
Husneara
My pc processor number is :
Intel(R) Core(TM) i3-3220 CPU @ 3.30 GHz 3.30 GHz
I have downloaded it from this link:
http://support.intel.com/support/processors/tools/piu/sb/cs-014921.htm
AlHill
Husneara
I am facing the same problem while installing it from your link.
AlHill
Then, you likely have a windows problem.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Husneara
Here are the results of the utility. Check out the attached files.
Husneara
Here is the txt. file
LeonWaksman
Hi @Husneara
Did you tried to install the Intel Processor Diagnostic Tool? Do you have Windows 10 O.S.?
Leon
Husneara
Husneara
I have attached the test result that I have done with  Intel Processor Diagnostic Tool.
AlHill
Ok, are we talking about the Intel processor identification utility
or the Intel processor diagnostic tool?
I gave you a link to the Intel processor identification utility.  Did you try it?
Husneara
Sorry, I did not find any link. Will you please send it again?
AlHill
scroll down in this thread.
Alberto_Sykes
Hello Husneara, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the issue with the Intel® Processor Identification Utility still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
Alberto_Sykes
Hello Husneara, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
