Processors
16101 Discussions
Compatibility with Xeon E5 2680 V4 and Windows 11 and Alternatives for Upgrade
MiDe
We currently have installed E5-2690 v4 (HP Z840) on several Workstations
PC Health Check tells me: "This processor is currently not supported by Windows 11" - original message is German, so it might be slightly different. Rest of requirements are all met.
But my question is towards Intel:
Do you have a list of compatible Processer to C612 with similar or higher performance to E5-2690 v4, I can replace in my system to be Windows 11 compatible?
best regards
MiDe
Victor_G_Intel
Hello MiDe,
Since your system is an OEM from HP, please bear in mind that the compatibility with your motherboard is information that we don’t handle since we only know the compatibility of our boards; therefore, if you would like to know what processor models your system is compatible with so you can upgrade it you will need to contact HP directly.
Additionally, Microsoft has published a publicly available list of all the processors compatible with Windows 11, if you like you can take their list as a reference once you contact HP’s support directly.
Windows 11 supported Intel processors
https://learn.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-intel-processors
Also, just so you know once you have the compatible options for your system you can use the steps in the link below to compare any processor that you like with the one you currently have so you can make your decision based on specs.
How do I View or Compare Features for Intel® Xeon® Processors?
https://www.intel.com/content/www/us/en/support/articles/000031588/processors/intel-xeon-processors.html
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello MiDe,
Please let me know if you still need further assistance.
Victor G.
Victor_G_Intel
Hello MiDe,
We have not heard back from you.
Victor G.
