Buenas,
Mi ordenador cuenta con una gráfica 2080Ti. También con un procesador i5 6600k y 16 GB de RAM DDR4.
Me gustaría saber si esta sufriendo de cuello de botella, y si es el caso, que procesador le podría poner.
No tengo presupuesto en general, así que sea el mejor recomendado para una 2080ti.
Gracias
You mean i7-7700k, correct?
If so, you can compare the two processors here:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=97129,88191
If you want to upgrade your processor, you will have to ask your device/motherboard manufacturer what processors their BIOS supports. Then, you can select from those. You likely will not be able to upgrade to anything other than another 6th gen processor. But, check with your motherboard manufacturer first.
Hi, thank you
I checked it and the max. I can buy for my maximus VIII hero is a i5 7700K.
I think it would be a good improvment, right?
Hahaha sorry, yes, I meant i7.
Thank you, I think I will get a i7-7700k.
