bought 'Driver Easy' , It fixed 22 drivers on one machine and 27 on another. Problems went away and everything is working fine now. Could not find a easy solution here, that one was easy and was mentioned as one to use on the Microsoft website.
Hello wrgraves,
Thank you for posting on the Intel® communities. I understand you are having issues with your Intel® Driver & Support Assistant (Intel® DSA)
1. When did you notice this issue?
2. Were you able to install the Intel® Driver & Support Assistant (Intel® DSA) before?
3. Do you get any errors during or after the installation?
Deivid A.
It appears that DSA is extremally slow on my hardware and may even hang till I reboot. it took 3.5 hours for the setup to complete with no errors or other output and then the first hardware scan didn't complete until the next day when I powered up the in the morning. It didn't seem that useful as 'Driver Easy' reported 22 drivers out of date, most of them intel but DSA only fixed 2. So DSA is installed now. Not sure what to do about the other 17 out out of date intel drivers.
@wrgraves "Not sure what to do about the other 17 out out of date intel drivers. " Do not believe them.
Please do yourself a favor and NOT use 3rd party driver sites like driver easy. You never know what information from your machine they are uploading (and to what country it is going), and you never know what payload is in the packages they are downloading.
[Waiting for Windows 12]
