Processors
14593 Discussions
Does Skylake-X Support Triple Channel Memory?
So Skylake-X clearly supports Dual-Channel and Quad-Channel memory but it seems weird to me that I don't see anything about Triple-Channel memory. Does it really only support dual and quad channel? Will using three sticks result in the ram running as single channel?
Hello Wandor
Thank you for joining the community.
Could you provide us with the model of the processor you are interested in?
Leonardo C.
Thank you for replying,
the ones I am interested in are the i7-7820X and i9-7980XE
Chris
Hello Wandor
Thank you for your response.
I am looking into the datasheet for the processors that you are interested to get for the system memory support allow me to share with you the memory specification on the following link on page 9 section 1.3.1
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/6th-gen-x-series-datasheet-vol-1.pdf https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/6th-gen-x-series-datasheet-vol-1.pdf
Leonardo C.
AlHill
Leonardo, are you sure that link is correct?
Doc
