Hi there,
I'm currently using an i7-14700. Inside Asus B760 BIOS (1604), its IccMax value is set to 511A.
I would like to know Intel's recommended IccMax value for i7-14700, thanks!
511A is hard to believe.
You just became a believer haha
B760, just as probably all B series chipset, does not allow overclocking, changing any voltage or in this case the Amps, will definitely result in BSOD. Leaving it at default is best.
Value of 511A will be lower depending on selected profile.....at least i can make it show other values, i think there are 3 main profiles.....
Theoretically, a TDP of 300W and 1,4V CPU core voltage will result in current being close to 214A. So not even close to 511A.
Changing that value in XTU is at least for me is not possible, not with the B760
![](/skins/images/8C80966F940F80D854AEDDDACECA968C/responsive_peak/images/icon_anonymous_message.png)
