Hi Guru's of the intel world, would like to get some answer regarding the temp of my CPU.
Is the temp normal or something else, i m using a good air cpu cooler Spire Thermax Eclipse II ( dual fans )
I attach a screen shot of the temps after 3dmark Spy TIme benchmark. Thank in advance.
Hello Thong1234:
Thank you very much for providing the picture, it is very useful for us to further assist you.
The Intel® Core™ i5-6600K Processor could reach up to 64°C inside the case, and that is expected, as you can confirm on the following link:
http://ark.intel.com/products/88191/Intel-Core-i5-6600K-Processor-6M-Cache-up-to-3_90-GHz?q=Intel%C2%AE%20Core%E2%84%A2%20i5-6600K%20Processor%20(6M%20Cache,%20up%20to%203.90%20GHz) http://ark.intel.com/products/88191/Intel-Core-i5-6600K-Processor-6M-Cache-up-to-3_90-GHz?q=Intel%C2%AE%20Core%E2%84%A2%20i5-6600K%20Processor%20(6M%20Cache,%20up%20to%203.90%20GHz)
I can see on the picture that the overall temperature for the processor is around 46°C, and that is normal, it is not getting overheating.
Is the PC throttling or getting freeze?
Did it went off by itself?
Those are the first symptoms of overheating, so if the PC is not doing that then it should be fine.
In addition, we do have a tool to test the processor as well, it does an overall test on it including the temperature test, the name of the tool is Intel® processor diagnostics tool, and it is very reliable, so, if the processor passed the test it means it is working fine:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Alberto
Hello Thong1234:
I just wanted to check if the information posted previously on this thread was helpful for you and if you need further assistance?
Alberto
Topic Options
