So i started doing some stress tests to see how the temperature behaved.
Once i started the test, the temperature would go to 90 almost instantly and the moment i stoped the test i would go to 50 instantly.
Which is not even possible to be happening because the processor needs some time to drop its temperature or to raise it.
Seeing this happening so rapidly makes me thing there is a problem with my processor thermometer.
It seems like the processor performance and its temperature are getting the same exact reading or something like that.
My processor is Intel core i7 - 5500u
How are you measuring the temperature?
CPUID HWMonitor
Try again, but use HWiNFO64 or (better) AIDA64. HWMonitor doesn't understand the motherboard or how the temperatures are represented (i.e. which sensor where) and may reflect bad information.
