Processors
15930 Discussions
Hi, my laptop has been crashing all the time. I run the I. processor D. tool and fails on prime number..
DEste5
Intel core i7-4510U CPU 2.00GHz
Asus X550LD
Diagnostic tool report:
Module Math_PrimeNum.exe Completed - Fail
No valid errorcode returned
Error Code -1
The problem is that now it went off like freezing then after a few minutes return
AlHill
You likely have an overheating problem.
Contact Asus on how to check the fan and any heatsink for proper operation.
Doc
DEste5
I've download the "CPUID HW monitor " to see if the temperature was high or not... and it stays always below the 60*C So I think is not a matter of overeating ( from my perspective).
I also check that the drive activity display near to the touchpad ( when the laptop is accessing the internal storage drives) when the computer frieze that light is not showing anything... so is like I have just a monitor showing a pic...
I try to run the memory analyzer and nothing appear to be bad. I went to the reliability report history and it's like an apocalypticCapture.PNG. Every day a app stop working and needs to be restart ...
AlHill
AlHill
Also, what version of Windows 10? 1909?
Doc
DEste5
My first coment on this was from that tool.
Today I change User and well it's a little faster... but it's stops anyway. I run the Tool again but on this user and it went a little further...
About the windowns version.. how can I know that? It just says "windows home 10" 64bits
Alberto_R_Intel
Hello DEste5, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the problem persists and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello DEste5, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Albert R.
DEste5
Hello Albert,
Thank you for your follow up. I didn't receive any notification about your first reply.
So, last friday I've downloaded an update driver software, and after a few updates the computer it's running OK again without crashing
Do you know why is that? or have any Idea ? The drivers weren't very old max since 2019/2018
The system is still failing on the prime number teste (intel processor diagnostic ) , it went a little further but it is failing anyway...
Thank you for feedback
Alberto_R_Intel
Hello DEste5, Thank you very much for letting us know those updates.
Perfect, excellent, it is great to hear that after the updates the computer, is running with no problems. In reference to your question about why that happened, it is hard to tell for sure, but for the good functionality of the equipment, it is always recommended to keep the drivers and Windows* up to date.
Just to let you know, the Intel® Core™ i7-4510U Processor should pass the Intel® Processor Diagnostics Tool test without failing the "Prime Number" section, so in this case, what we recommend is to get in contact directly with ASUS for them to provide further assistance on this matter and confirm if this might be a hardware problem:
https://www.asus.com/support/
Albert R.
DEste5
Thank you for your support. I will reach asus and then provide here an update
Alberto_R_Intel
Hello DEste5, You are very welcome, thank you very much for letting us know those details.
Great, that will be the next thing to do for this specific scenario.
Any other inquiry, do not hesitate to contact us again.
Albert R.
