Processors
15129 Discussions
High temperature I7-3930K
lPadu
i dont overclock, my cooler is http://www.legitreviews.com/thermaltake-water-2-0-performer-cpu-water-cooler-review_1938 Thermaltake Water 2.0 Performer CPU Water Cooler Review - Legit ReviewsThermaltake Water 2.0 Performer and the temperatura is high
load 10% the temperature up 75C
lPadu
Kevin_M_Intel
Hi Luiginho,
I would like to confirm some more information with you about the issue you have.
  1. Is this a first integration system?
  2. Have you tested the system outside of the chassis?
There are some troubleshooting steps that I would like you to try:
  1. If you have not tested the unit outside of the case, please take it out. By doing this we can discard a problem with the airflow on your system.
  2. Make sure the cooling solution is working properly.
  3. Clear the CMOS by removing the battery for about 20-30 minutes and then reconnect all devices.
  4. Update your BIOS using the latest provided by your computer manufacturer
Here are some links you can also refer to since are related to your issue:
http://www.intel.com/support/processors/sb/CS-029427.htm http://www.intel.com/support/processors/sb/CS-029427.htm
http://www.intel.com/support/processors/sb/CS-029426.htm http://www.intel.com/support/processors/sb/CS-029426.htm
