i dont overclock, my cooler is http://www.legitreviews.com/thermaltake-water-2-0-performer-cpu-water-cooler-review_1938 Thermaltake Water 2.0 Performer CPU Water Cooler Review - Legit ReviewsThermaltake Water 2.0 Performer and the temperatura is high
load 10% the temperature up 75C
Hi Luiginho,
I would like to confirm some more information with you about the issue you have.
- Is this a first integration system?
- Have you tested the system outside of the chassis?
There are some troubleshooting steps that I would like you to try:
- If you have not tested the unit outside of the case, please take it out. By doing this we can discard a problem with the airflow on your system.
- Make sure the cooling solution is working properly.
- Clear the CMOS by removing the battery for about 20-30 minutes and then reconnect all devices.
- Update your BIOS using the latest provided by your computer manufacturer
Here are some links you can also refer to since are related to your issue:
http://www.intel.com/support/processors/sb/CS-029427.htm http://www.intel.com/support/processors/sb/CS-029427.htm
http://www.intel.com/support/processors/sb/CS-029426.htm http://www.intel.com/support/processors/sb/CS-029426.htm
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
