So i want to use an atom cpu to try it out, so i can then is it in a project of some sort. As you can probably tell i'm not very experienced in intel atom cpu. Which one should i pick? How do i get started? And how do i get it to run some operating system? thanks.
- Tags:
- Intel Atom®
Hello rbbwa,
Thank you for joining the Processors community.
I would like to let you know that the right support regarding this Intel® product and your inquiry is provided by the Embedded Community, over here you will be able to find in-depth technical documentation, software, tools, and support for hardware developers, find the embedded community here: https://embedded.communities.intel.com/community/en Forum: Embedded Community |Embedded Community.
Amy C.
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
