Hello
I use E3845 (Baytrail-I) processor.
I had some temperature tests....
this test is Low temperature test...
The following measurement results were obtained.
After boot, DTS is not changed about 10minutes(38:08 ~ 48:09)...
temperature measure time after boottemperature sensor adjacent to the CPU (ºC) measured CPU temperature (ºC) DTS valueWed Nov 15 11:38:08.270 2017-35.50-9119 (0x77)Wed Nov 15 11:38:23.982 2017-34.50-9119 (0x77)Wed Nov 15 11:38:47.806 2017-33.50-9119 (0x77)Wed Nov 15 11:39:12.205 2017-32.50-9119 (0x77)Wed Nov 15 11:40:34.494 2017-30.00-9119 (0x77)Wed Nov 15 11:41:01.840 2017-29.00-9119 (0x77)Wed Nov 15 11:44:51.742 2017-23.50-9119 (0x77)Wed Nov 15 11:45:59.369 2017-22.50-9119 (0x77)Wed Nov 15 11:46:30.379 2017-22.00-9119 (0x77)Wed Nov 15 11:47:27.899 2017-21.00-9119 (0x77)Wed Nov 15 11:48:09.160 2017-20.50-9119 (0x77)Wed Nov 15 11:48:12.584 2017-20.50-8118 (0x76)Wed Nov 15 11:54:35.253 2017-16.50-5115 (0x73)I started search the reasons and found the following parts in CPU Monitoring With DTS/PECI.
So, What is the minimum reportable temperature by E3845 (BayTail-I) ?????????
JC
Sorry, I make a mistake in 10th line,
After booting, DTS did not change for about 10 minutes.(38:08 ~ 48:09)
Hi junfirst,
I understand you have an embedded processor with some questions about minimum DTS.
Please bear in mind that Intel will handle any issues with this processor model through the embedded team. Please post this issue https://embedded.communities.intel.com/community/en/ here, I am sorry for the inconvenience.
Allan J.
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
