Processors
13846 Discussions
I've been having problems with the extreme tuning utility and the truth is that it seems very strange to me since before I could normally do an undervolting of -150 and now it won't let me do anything at all ... please I need help.
BGonz20
Captura.JPGit's a core i5 8300H which allows undervolting already seen in several people and I have tried it. my computer is a dell g3 3975
AlHill
You have an H processor. XTU only supports X and K processors.
Uninstall XTU, and reset your bios to defaults.
Doc
BGonz20
I guess i'm a little confuse 'cause in the XTU have something called core voltage offset... I guess there is where I can undervolting my CPU... isn't? in this video, he teaches how to undervolting a core I7-8750H(https://www.youtube.com/watch?v=1DX1UJa65JM)... so I don't know if that is undervolting and that core have a H...
AlHill
Just look at the XTU download page under supported processors. You will see that H processors are not supported. That should relieve your confusion.
Doc
BGonz20
then why i could do undervolting?
AndrewG_Intel
Hello BGonz20
We would like to jump in and clarify and confirm that the information provided by Al.Hill is correct. Intel® Extreme Tuning Utility (Intel® XTU) is supported by unlocked processors. The list of supported processors is available at the bottom section of the download webpage under "This download is valid for the product(s) listed below."
Support is limited to valid processors and it is worth mentioning that Intel XTU may or may not work on unsupported processors. This information can be found on the official download webpage for Intel® Extreme Tuning Utility (Intel® XTU).
Altering clock frequency and/or voltage may reduce system stability and useful life of the system and processor; cause the processor and other system components to fail; cause reductions in system performance; cause additional heat or other damage, and affect system data integrity. Intel has not tested, and does not warranty, the operation of the processor beyond its specifications. We highly recommend contacting your computer manufacturer (OEM) to check the availability and/or possibility of tools, steps and/or options to perform changes on the BIOS regarding processor frequency and voltage (if applicable).
Andrew G.
cujj
Hello. i also have the same problem with the same cpu. I had modified the values of "Core Voltage Offset", "turbo boost short / power max / time windows" because my laptop got too hot, while with the changed values I had a good compromise. yesterday I realized that the "Core Voltage Offset" value is no longer editable; why did this happen? the version of xtu is 6.5.1.360 and although I read that my cpu is not supported, I reiterate the fact that until yesterday I could easily change the values.
is there a solution? thank you
AndrewG_Intel
Hello cujj
Regarding your inquiry, we would like to inform you that support is limited to valid processors. Intel XTU may or may not work on unsupported processors (e.g. Intel® Core™ i5-8300H Processor). This information can be found on the official download webpage for Intel® Extreme Tuning Utility (Intel® XTU). Intel® XTU is supported by unlocked processors.
We do not recommend altering clock frequencies or voltage, this may reduce system stability and useful life of the system and processor. We recommend running the system in the default BIOS settings recommended by the computer/laptop manufacturer (OEM).
In the scenario of experiencing overheating issues, we do not recommend changing BIOS settings without guidance from your OEM. In laptops, All-in-One computers (AIO), tablets, etc., the cooling solution, thermal dissipation system, etc, are designed and integrated by the OEM to work under their specific conditions and your OEM has determined what would be the expected working behavior. We recommend checking with your OEM regarding instructions and/or tools available from their side to alter BIOS settings (if applicable).
Andrew G.
