I have a new system, and after some hours of use, it starting giving me Blue Screens. All the settings are default / auto in UEFI.
After checking every component and testing the memory, I found that disabling Turbo Boost fix the problem.
Also, using Turbo Boost and the adaptive offset settings with +0.045 v is more stable, but I get a BSOD when doing a stress test.
I want to use the Turbo feature, so I would like to know if this can be caused by a defective CPU. Should I ask the reseler to change my CPU?
My componentes:
Asus TUF Z370-PLUS GAMING
Intel® Core™ i7-8700 CPU @ 3.20GHz
Corsair DDR4-3200 8 GB x 2
PSU Gigabyte G750H
Download, run, and ATTACH the results of this utility. Then, an Intel support engineer can assist you.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
Thank you, I created a support request with the tool.
