17083 ディスカッション
Initialization sequence i386 EX
AolivaG
ビギナー
1,560件の閲覧回数
Hi everyone,
I am now working trying to repair a device that contains the embedded microprocessor i386 EX.
I am kind of a rookie with this processor and I would like to know if there is a way to check if it is doing the correct steps in order to be initialized into normal operation, or if it is doing something "wrong" and jumping into a different mode.
I do not have any information about the hypothetical programming work that could have been done in the processor so I can not give much more details about that, and I do not know if that is a key factor in my problem but I have not found any manual that talks about it.
I also know that it is a very old processor and that is why I am trying to explore all my possible options to find a solution.
I want to thank you all beforehand!
0 件の賞賛
1 返信
AlHill
スーパーユーザー
1,555件の閲覧回数
This goes back 30 years.   I doubt intel will provide anything useful.
And, I doubt this will help:
https://web.archive.org/web/20090507105011/http://www.ssv-embedded.de/ssv/pc104/p8.htm
Good luck with your project.
返信
