hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Processors
16232 Discussions
Intel 13600k with MSI Z690-A PRO WIFI with DDR5 Windows 11 can't undervolt
AndreiDev
Hi guys,
I used to have an Intel 12600K with MSI Z690-A PRO WIFI with DDR5 and undervolting worked great from windows with the help of Intel XTU but once I upgraded to 13600k can't undervolt anymore.
I'm using windows 11 with latest updates and drivers, latest bios on MB.
If I set the offset from bios -0.100v  when I get back to bios I see the difference but if I load windows it ignores the undervolt completly... if I try to overvolt +0.50v that works...
Any ideas on what might be the issue here?
Alberto_R_Intel
AndreiDev, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, it is important to mention that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. Check with the manufacturers of system and components for additional details.
The Intel® Core™ i5-13600K processor is fully compatible with the Intel® XTU tool:
https://www.intel.com/content/www/us/en/download/17881/intel-extreme-tuning-utility-intel-xtu.html?wapkw=xtu
Did you try to uninstall and reinstall the Intel® XTU application?
In the following link you will find the "Common Issues and Resolutions for Intel® Extreme Tuning Utility" with some troubleshooting steps that might be useuful for you:
https://www.intel.com/content/www/us/en/support/articles/000005774/processors/processor-utilities-and-programs.html
Additionally, since the Intel® XTU is directly related to the BIOS, we also recommended to get in contact directly with MSI Support to make sure the latest BIOS version is currently installed in the board or to gather the instructions on how to update it:
https://www.msi.com/support
Once you get the chance, please let us know the results. If the problem persists, please attach the SSU report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs":
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
AndreiDev
Hi Albert.
Thanks for your reply, I have tried to re-install XTU but the same thing happens, it ignores any undervolt I try to apply but it does apply overvoltage if it try.
... so an offset of -0.050v is ignored but one of +0.050v gets applied.
this only happens in windows, at the bios level offsets get applied correctly  but once windows loads.... it starts ignoring the negative offset again.
also any frequency modification gets applied correctly, the only thing that does not is undervolting.
it's not a MSI issue since the bios applied any offset correctly, something happens after windows gets loaded that ignores my negative offsets.
Alberto_R_Intel
Hi AndreiDev, You are very welcome, thank you very much for providing that information.
We are sorry to hear the issue persists after trying the troubleshooting steps provided previously.
We will do further research on this matter. For us to be able to do that, please attach the SSU report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs":
Albert R.
AndreiDev
Sure thing, here is the SSU report you asked for.
Alberto_R_Intel
AndreiDev, Thank you very much for sharing the SSU report.
We will do further research on this matter. As soon as I get any updates, I will post all the details on this thread.
Albert R.
AndreiDev
Thank you for trying to help me with this issue I appreciate it.
Alberto_R_Intel
AndreiDev, You are very welcome.
We are here to help.
Albert R.
Alberto_R_Intel
Hello AndreiDev, I just received an update on this matter.
While we are still working on this case, we just wanted to check if you could please provide pictures or screenshots from Intel® XTU about this scenario so we can have a better understanding of the options you are currently seeing on the tool?
Albert R.
AndreiDev
I have attatched 3 screenshots with XTU as you asked.
First are default values, they work normal.
2nd are undervolt values... they are ignored and work with default.
3rd are overvolt values... they worked but who needs overvolting..
Any Mhz overclock or underclock I try works fine... the only issue is undervolting.
And also if I undervolt from bios and reset computer then go back to bios... bios aplies undervolt but as soon as I load windows it ignores undervolt values and snaps back to stock voltage values.
Alberto_R_Intel
Hello AndreiDev, Thank you very much for clarifying those details and sharing the files.
We will continue with our research on this scenario. As soon as I get more information, I will post all of it on this thread.
Albert R.
AndreiDev
Hey I just wanted to let you know I went back to my old 12600K CPU.
Don't waste any more time with this, it's ok.
Thank you again for trying to help me out.
Also happy holydays
texen
Since you have a MSI z690 MB.. this is prob the best way to undervolt
https://www.youtube.com/watch?v=-mkAVITZoLY
I have my CPU Lite Load  set at Mode 3 .. not had any problems
Alberto_R_Intel
Hello AndreiDev, You are very welcome, thank you very much for your response.
We completely understand your decision of going back to using the Intel® 12600K processor.
Still, just to let you know, we are currently working on this scenario, and we recommend:
-To check if undervolt protection is unabled on BIOS.
-To get in contact directly with MSI Support to make sure the latest BIOS version is currently installed:
-To install the new Intel® XTU version 7.10.0.65 that was released on 12/22:
We apologize for any inconvenience.
Albert R.
Alberto_R_Intel
Hello AndreiDev, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello AndreiDev, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
