I have ZOTAC-ION ITX board (Intel Atom N330, NVIDIA ION GPU) running. Its power consumption statistics are as follows: Hibernate: 2W, Sleep: 3W, Idle: 25W, CPU load : 30W (average).
I am working on a dynamic power management project where I need the complete power model of the board, i.e., the transition times to switch among different power modes and the resulting power consumption incurred during the mode transition. Is there any way I can get these statistics?
For the type of information that you need, I would suggest contacting any of our local Authorized Intel® Distributors, and ask them to put you in contact with a Field Application Engineer (FAE), they will be able to assist you with this matter.
You can find a list of Authorized Intel® Distributors at:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
If you are outside the United States, please access the following link and select a location, to find the closest authorized distributor:
http://premierlocator.intel.com/Default.aspx http://premierlocator.intel.com/Default.aspx
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
