Hello, can anyone help me?
I installed Intel Performance Maximizer but cant access to use cuz i get message:
Intel® Performance Maximizer cannot test this system because the current BIOS does not support Intel® Watchdog Timer Driver (Intel® WDT).
I updated all drivers.
Motherboard: ASROCK X299 TAICHI CLX
Processor: Intel Core i9 10980XE
Look on screens and you will see i have all required drivers
Hello maksvalmont,
I understand that you are unable to access the Intel® Performance Maximizer tool.
To better assist you I would appreciate if you could provide the following information:
- Is this the first time that you are using this utility? Or was the it working fine before?
- Please provided the link where you download the software.
- Please provide more details about the updates made
To gather more information about your system please run the following tool and attach the reports generated.
Intel® System Support Utility (Intel® SSU) Download link
1. Open the application and click on "Scan" to see the system and device information.
2. By default, Intel® SSU will take you to the "Summary View".
3. Click on the menu where it says "Summary" to change to "Detailed View".
4. To save your scan, click on "Next", then "Save".
Esteban D.
My first time install
Download Link:
downloadcenter.intel.com/ru/download/29436/Intel-Performance-Maximizer-Intel-Core-X?product=188727
Windows 10 x64 (20H2)
Can you hide my SSU.txt from another community users?
Hello maksvalmont,
Thank you so much for your response.
I would like to inform you that the SSU report was removed from the thread so the information is available only to us.
After reviewing the information on our side and checking the error message, I need to inform you that this behavior (as the error message states) is directlly related to BIOS configuration.
There are some BIOS Setup Requirements for this utility and the Intel Watchdog Timer Driver must be enabled in BIOS. This and other BIOS requirements can be found in point 3.2.4 of the user guide.
The possible cause for this error message is that necessary overclocking hardware resources are not accessible by Intel Performance Maximizer.
Our recommendations would be to contact your motherboard manufacturer about this or check for an updated BIOS. (Please check p.25 of the user guide)
I hope this helps to answer your concern.
Esteban D.
Before registration here, i read alot of much posts about this driver, i have seen already about requirements 3.2.4.
Processor Core Overclocking must be enabled•All Processor cores must be enabled•Intel® Hyper-Threading Technology (Intel® HT Technology), if supported on the processor,must be enabled•Intel® Turbo Boost Technology 2.0mode must be enabled •Boot mode must be UEFI•Enhanced Intel SpeedStep® Technologymust be enabled•Intel® Watchdog Timer Driver (Intel® WDT) must be enabled
It's easy to turn it on
All enabled in bios, then i reinstall driver, then i register here and created post.
Eh thnx i understand you cant help me (
Hello maksvalmont,
Thank you for your response.
I hope that you are able to resolve this matter after reviewing with your motherboard manufacturer.
Please consider that sometimes, this feature may be locked by them so I would strongly recommend contacting your Original Equipment Manufacturer (OEM) for the latest BIOS update and reviewing the driver functionality.
As you require direct assistance from them, I will proceed with the closure of your inquiry.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
