Processors
14581 Discussions
Intel® DSA is not Detecting my Devices
Al3bird
Intel® Driver & Support Assistant (Intel® DSA) is not Detecting my Devices as I get Error: "Sorry, something went wrong while trying to scan."
Não estou conseguindo atualizar meus drivers no Assistente de driver e suporte Intel. Sempre aparece a mensagem que algo deu errado.
JosueO_Intel
Hello Al3bird,
Thank you for posting on the Intel communities. Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
In order to have a better understanding of the issue, please share with us the following information:
  1. Was it working before?
  2. When did the issue start happening?
  3. Which browser are you using?
  4. Latest Intel Driver & Support Assistant log files: using File Explorer: go to folder = C:\ProgramData\Intel\DSA, and zip the Log files or entire folder.
Also, please download and install the Intel System Support Utility (Intel SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response.
Josue O.
JosueO_Intel
Hello Al3bird,
Josue O.
JosueO_Intel
Hello Al3bird,
Josue O.
