The Intel Extreme Tuning Utility(7.7.0.12) is reporting the wrong amount of memory on my EVGA GeForce 3060 RTX. Posting the memory at 4.00 Gb which in fact it has 12 Gb.
Thank you
Hello Matt6799.
Regarding your issue, I would like to have more information about it to provide you with the most accurate troubleshooting; please provide me with the following:
- When did the issue start?
- Can you recall any hardware or software change before the issue started?
- Share a screenshot of the Intel® XTU where you see the issue with the memory information about the GPU.
- Create a report using the Intel
System Support Utility (Intel SSU)
• Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html)
• Open the application and click on "Scan" to see the system and device information. By default, Intel
To save your scan: click on "Next"; then "Save."
Jean O.
Hello Jean O.
Is there any info update as to why the Intel SSU is reporting the wrong amount of memory on my video card?
Thank you,
Matt
Hello Matt6799,
There is no information about any error on the Intel® XTU or Intel
Jean O.
Hello Matt6799,
I hope you are doing fine.
Jean O.
Hello Matt6799,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
![](/skins/images/97EBD289F799093125F556C07FADEBA3/responsive_peak/images/icon_anonymous_message.png)
