What incompatibility problem? There is no incompatibility problem. When he used memory that is within the specs of the processor (i.e. 4800MHz), it worked just fine. All bets are off once you go beyond the processor's specs, however. When you exceed the specs and it doesn't work, 99% of the time it is the motherboard (and its BIOS) that is responsible.
P.S. They are called POST Codes.
Hello VictoryPete,
Were you able to check the previous response? There has been responses to your threads, but we do not receive any response from you after that.
Are you having any specific issues with your 12th generation processor and a DDR5 RAM.
Steven G.
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
![](/skins/images/F0F49BD5F2C539F9177C31EE54F848B4/responsive_peak/images/icon_anonymous_message.png)
