Processors
15767 Discussions
Intel Xeon E5440 (Harpertown) Stepping Codes
Greetings I have an E5440 processor with stepping code (sSpec) SLANS and a S5000XVN board.
I was looking for a second processor for a dual CPU system and all I could find was an E5440 Q9CU from a supplier. The supplier claims that Q9CU is actually SLANS. I looked on the stepping codes and found out that SLANS is the production sSpec of Q9CU and they belong to the same Core Stepping which is C0.
Still I cannot guess what that means. Does it mean that they're actually the same? That they'll simply work together because they're quite similar? Or that they won't work?
Any help would be appreciated!
DSilv11
Valued Contributor III
I would stear clear.
Q9CU is an http://www.intel.com/support/processors/sb/CS-030747.htm?wapkw=engineering%20sample%20processor engineering sample processor and the properity of Intel Corporation.
  • Intel ES Processors are the sole property of Intel
  • Intel ES Processors are Intel Confidential
  • Intel ES Processors are provided by Intel under nondisclosure and/or special loan agreement terms with restrictions on the recipient's handling and use
  • Intel ES Processors are not for sale or re-sale
  • Intel ES Processors may not have passed commercial regulatory requirements
  • ES Processors are not covered under Intel warranty and are generally not supported by Intel
http://www.intel.com/support/processors/sb/CS-030747.htm?wapkw=engineering%20sample%20processor http://www.intel.com/support/processors/sb/CS-030747.htm?wapkw=engineering sample processor
Thanks on that information, obviously if this is a sample processor I'd stay away from it, but that makes you wonder how it ended up for sale!
