I'm running on a HPC cluster with blades running dual Intel Xeon Platinum 8176.
The specs say that the base frequency is 2.1 GHz, but the max frequency should be up to 3.8 GHz when running on a single core, and somewhere less when running on more cores (see here)
However when I use the command lscpu I get the following:
# lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 112
On-line CPU(s) list: 0-111
Thread(s) per core: 2
Core(s) per socket: 28
Socket(s): 2
NUMA node(s): 2
Vendor ID: GenuineIntel
CPU family: 6
Model: 85
Model name: Intel(R) Xeon(R) Platinum 8176 CPU @ 2.10GHz
Stepping: 4
CPU MHz: 2101.000
CPU max MHz: 2101.0000
CPU min MHz: 1000.0000
BogoMIPS: 4200.00
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 1024K
L3 cache: 39424K
NUMA node0 CPU(s): 0-27,56-83
NUMA node1 CPU(s): 28-55,84-111
This seems to suggest that the TurboBoost is not enable in the BIOS, but when I run cpupower frequency-info it seems to say it actually is:
# cpupower frequency-info
analyzing CPU 0:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 10.0 us
hardware limits: 1000 MHz - 2.10 GHz
available frequency steps: 2.10 GHz, 2.10 GHz, 2.00 GHz, 1.90 GHz, 1.80 GHz, 1.70 GHz, 1.60 GHz, 1.50 GHz, 1.40 GHz, 1.30 GHz, 1.20 GHz, 1.10 GHz, 1000 MHz
available cpufreq governors: conservative userspace powersave ondemand performance
current policy: frequency should be within 1000 MHz and 2.10 GHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 2.10 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
What else could be limiting the max frequency to the base frequency?
Claudio
If you are separately running a application that is spread across all available cores, then the Turbo Boost feature will most definitely NOT be active. This feature is specifically used when relatively few cores are active. It is trying to make use of any thermal and power headroom that is available to boost the performance of the few cores that are active. There will simply not be any headroom if all cores are active.
There are a number of apps around that monitors the Turbo Boost feature. There is even one from Intel (Intel Turbo Boost Technology Monitor 3.0). Try running this tool.
It does not suggest that at all; you are making bad assumptions (yes, I am rolling my eyes). This lscpu software is simply showing the range of processor frequencies it could see during its operation. It tells us that it just happens that Turbo Boost was not being used while this tool was running. The cpupower tool is telling you the frequencies that are used for idling down the processor when it is not busy. This also has nothing to do with Turbo Boost either.
Scott,
when the tool was running a CFD simulation was also running on all 56 cores. the load average was 56 and had been that for a while (i.e. hours). So I expected that the CPU MHz: line in the lscpu output, which to my knowledge show the current cpu frequency to be much more than the 2101.000 value. Isn't that the case?
Since TurboBoost is enable, if it is not running when the CPU is completely loaded, when is it supposed to be running?
I ended up using turbostat to find the answer I was looking for.
Yes, TurboBoost is enable and IS active.
turbostat confirm the when all cores were busy, they were running around about 2.4-2.5 GHz, which is the results I was excepting since the application running uses AVX2 (See https://en.wikichip.org/wiki/intel/xeon_platinum/8176).
Cheers.
![](/skins/images/54BF544B471F3F61DFD338F1D58F9426/responsive_peak/images/icon_anonymous_message.png)
