http://www.newegg.com/Product/Product.aspx?Item=N82E16819116371 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116371
Just wondering, i have never installed a CPU before so trying to ask around about a couple things first.
Oh sorry by fan i mean fan and heat sink.
The stockfan and heatsink should be sufficient for the CPU on nominal frequencies. The CPU won't run as cool or silent as it could when you use a aftermarket cooling solution, but it should do. And if you want to overclock the CPU then you should consider a aftermarket cooling solution
Go Back to NewEgg and look at the Coursair , H-50 . H2O Cooler Real quite and better than any air cooler . $ 75.00. Than you can crank up your Wolfdale as much as you want.
Thanks guys. Thats what i needed to know.
I may try OCing later when I can afford a cooler. Never OC'd before and dont have the money for a better cooler anyhow.
Stock is fine for me working great since i first posted.
![](/skins/images/DC0E2679F7049B943291D1ED082A478E/responsive_peak/images/icon_anonymous_message.png)
