Hi..
I'm thinking of buying a bay-trail with J2900 on it. Can you confirm if decodes HD Audio (DTS-HD MA and Dolby TrueHD)?
I know that Intel have some issues with HD Audio with J1900, are they fixed with J2900?
Thanks in advance.
Hello Wanthd, thanks a lot for posting your question at Intel communities.
I'm afraid to tell you that the issue with the J1900 is still escalated, please check the following thread for additional information on this.
/message/244997# 244997 https://communities.intel.com/message/244997# 244997
I'm going to check about this with the J2900. I'll let you know.
Thank you for your answer.
When will you have an answer for this question about J2900?
I'm depending on your answer to buy your product.
Thanks in advance.
I'm sorry Wanthd, but I'm still waiting for the correct information.
Hi..
Almost a month later, still no answer about this BIG problem?
I think i will give up on buy this processor.
According to engineering, they are currently working on new drivers that will address this matter on the J1900. The J1900 and the J2900 are likely the same so I guess both are going to experience the same behavior.
Thanks for your patience and understanding.
I've seen that Intel has released new drivers a week ago, on Oct 24. Did this drivers solved this problem?
When is expected this issue to be resolved?
Already passed 2 months and no news...
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
