Processors
14956 Discussions
Lenovo miix 830 XTU compatibility ETA
doneh
http://www.notebook-driver.com/specs/lenovo-miix-3-830-tablet-tech-specs/ http://www.notebook-driver.com/specs/lenovo-miix-3-830-tablet-tech-specs/
Cant find the chipset but it has a atom baytrail z3735f cpu and hd4000 gpu.
I tried 5.1 and just now the 5.2 but my platform isnt supported.
doneh
[0A80:0F4C][2015-05-29T04:19:30]: Burn v3.6.2803.0, Windows v6.2 (Build 9200: Service Pack 0), path: C:\Users\Tim\AppData\Local\Microsoft\Windows\INetCache\IE\AJ9DE360\XTU-Setup-exe.exe, cmdline: ''
[0A80:0F4C][2015-05-29T04:19:30]: Initializing string variable 'RemoveAllDataCheckboxValue' to value '[RemoveAllDataCheckbox]'
[0A80:0F4C][2015-05-29T04:19:30]: Setting string variable 'WixBundleLog' to value 'C:\Users\Tim\AppData\Local\Temp\Intel_Extreme_Tuning_Utility_20150529041930.log'
[0A80:0F4C][2015-05-29T04:19:30]: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Tim\AppData\Local\Microsoft\Windows\INetCache\IE\AJ9DE360\XTU-Setup-exe.exe'
[0A80:0F4C][2015-05-29T04:19:30]: Condition 'VersionNT >= v6.1' evaluates to true.
[0A80:0F4C][2015-05-29T04:19:30]: Setting string variable 'WixBundleName' to value 'Intel Extreme Tuning Utility'
[0A80:0F4C][2015-05-29T04:19:30]: Detect 4 packages
[0A80:0F4C][2015-05-29T04:19:30]: Detected package: MEISetup.exe, state: Absent, cached: None
[0A80:0F4C][2015-05-29T04:19:30]: Detected package: SSCERuntime_x86_ENU.msi, state: Present, cached: None
[0A80:0F4C][2015-05-29T04:19:30]: Detected package: SSCERuntime_x64_ENU.msi, state: Absent, cached: None
[0A80:0F4C][2015-05-29T04:19:30]: Detected package: XTU_Setup.msi, state: Absent, cached: None
[0A80:0F4C][2015-05-29T04:19:30]: Detect complete, result: 0x0
[0A80:0F4C][2015-05-29T04:19:33]: Plan 4 packages, action: Install
[0A80:0F4C][2015-05-29T04:19:33]: Skipping dependency registration on package with no dependency providers: MEISetup.exe
[0A80:0F4C][2015-05-29T04:19:33]: Setting string variable 'WixBundleLog_MEISetup.exe' to value 'C:\Users\Tim\AppData\Local\Temp\Intel_Extreme_Tuning_Utility_20150529041930_0_MEISetup.exe.log'
[0A80:0F4C][2015-05-29T04:19:33]: Condition 'VersionNT64' evaluates to false.
[0A80:0F4C][2015-05-29T04:19:33]: Setting string variable 'WixBundleRollbackLog_XTU_Setup.msi' to value 'C:\Users\Tim\AppData\Local\Temp\Intel_Extreme_Tuning_Utility_20150529041930_1_XTU_Setup.msi_rollback.log'
[0A80:0F4C][2015-05-29T04:19:33]: Setting string variable 'WixBundleLog_XTU_Setup.msi' to value 'C:\Users\Tim\AppData\Local\Temp\Intel_Extreme_Tuning_Utility_20150529041930_1_XTU_Setup.msi.log'
[0A80:0F4C][2015-05-29T04:19:33]: Planned package: MEISetup.exe, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[0A80:0F4C][2015-05-29T04:19:33]: Planned package: SSCERuntime_x86_ENU.msi, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[0A80:0F4C][2015-05-29T04:19:33]: Planned package: SSCERuntime_x64_ENU.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0A80:0F4C][2015-05-29T04:19:33]: Planned package: XTU_Setup.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[0A80:0F4C][2015-05-29T04:19:33]: Plan complete, result: 0x0
[0A80:0F4C][2015-05-29T04:19:33]: Apply begin
[1520:0664][2015-05-29T04:19:39]: Creating a system restore point.
[1520:0664][2015-05-29T04:19:39]: Could not create system restore point, error: 0x80070422. Continuing...
[1520:0664][2015-05-29T04:19:39]: Caching bundle from: 'C:\Users\Tim\AppData\Local\Temp\{c39ccdf6-4cad-48b9-87d8-00131589afca}\.be\xtu-setup-exe.exe' to: 'C:\ProgramData\Package Cache\{c39ccdf6-4cad-48b9-87d8-00131589afca}\xtu-setup-exe.exe'
[1520:0664][2015-05-29T04:19:39]: Registering bundle dependency provider: {c39ccdf6-4cad-48b9-87d8-00131589afca}, version: 5.2.0.14
[1520:0D00][2015-05-29T04:19:40]: Verified acquired payload: MEISetup.exe at path: C:\ProgramData\Package Cache\.unverified\MEISetup.exe, moving to: C:\ProgramData\Package Cache\2EA0148C3093F7D274187E971810A7ECE7144803\MEISetup.exe.
[1520:0D00][2015-05-29T04:19:40]: Verified acquired payload: XTU_Setup.msi at path: C:\ProgramData\Package Cache\.unverified\XTU_Setup.msi, moving to: C:\ProgramData\Package Cache\{02874FB3-3E27-4A14-96B8-1562F5A04A31}v5.2.0.14\XTU-Setup.msi.
[1520:0664][2015-05-29T04:19:40]: Applying execute package: MEISetup.exe, action: Install, path: C:\ProgramData\Package Cache\2EA0148C3093F7D274187E971810A7ECE7144803\MEISetup.exe, arguments: '"C:\ProgramData\Package Cache\2EA0148C3093F7D274187E971810A7ECE7144803\MEISetup.exe" -s'
[1520:0664][2015-05-29T04:19:45]: Registering dependency: {c39ccdf6-4cad-48b9-87d8-00131589afca} on package provider: {3A9FC03D-C685-4831-94CF-4EDFD3749497}, package: SSCERuntime_x86_ENU.msi
[1520:0664][2015-05-29T04:19:45]: Applying execute package: XTU_Setup.msi, action: Install, path: C:\ProgramData\Package Cache\{02874FB3-3E27-4A14-96B8-1562F5A04A31}v5.2.0.14\XTU-Setup.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" REMOVEALLAPPDATA=""'
[1520:0664][2015-05-29T04:19:53]: Error 0x80070643: Failed to install MSI package.
[1520:0664][2015-05-29T04:19:53]: Error 0x80070643: Failed to execute MSI package.
[0A80:0F4C][2015-05-29T04:19:53]: Error 0x80070643: Failed to configure per-machine MSI package.
[0A80:0F4C][2015-05-29T04:19:53]: Error 0x80070643: Failed to execute MSI package.
[1520:0664][2015-05-29T04:19:53]: Skipped rollback of package: XTU_Setup.msi, action: Uninstall, already: Absent
[1520:0664][2015-05-29T04:19:53]: Removing cached package: XTU_Setup.msi, from path: C:\ProgramData\Package Cache\{02874FB3-3E27-4A14-96B8-1562F5A04A31}v5.2.0.14\
[1520:0664][2015-05-29T04:19:53]: Removing dependency: {c39ccdf6-4cad-48b9-87d8-00131589afca} on package provider: {3A9FC03D-C685-4831-94CF-4EDFD3749497}, package SSCERuntime_x86_ENU.msi
[1520:0664][2015-05-29T04:19:53]: Removing cached package: MEISetup.exe, from path: C:\ProgramData\Package Cache\2EA0148C3093F7D274187E971810A7ECE7144803\
[1520:0664][2015-05-29T04:19:53]: Removing bundle dependency provider: {c39ccdf6-4cad-48b9-87d8-00131589afca}
[1520:0664][2015-05-29T04:19:53]: Removing cached bundle: {c39ccdf6-4cad-48b9-87d8-00131589afca}, from path: C:\ProgramData\Package Cache\{c39ccdf6-4cad-48b9-87d8-00131589afca}\
[0A80:0F4C][2015-05-29T04:19:54]: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
Kevin_M_Intel
Hello delibin,
You should be able to install the XTU without any problem but if there is any compatibility issue with the platform you have it will not be installed.
My recommendation is to contact the tablet manufacturer and confirm with them if this software can be installed or if there is any type of limitation causing this problem.
Kevin_M_Intel
Hello delibin,
doneh
Kevin_M_Intel
Hello delibin,
Kevin_M_Intel
Hello delibin,
