hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Processors
16376 Discussions
Newly Built PC, BSOD Crashes, I think it may be the CPU
KAitk1
Débutant
6 399 Visites
Hi All,
First time posting here, been using Intel CPU's for the past 15 years but never had an issue that I thought might be the CPU until now. I'm hoping someone can provide some firm insight as to what my problem might be so I can do the necessary RMA.
Built my PC about 10 days ago and have been getting blue screen crashes. Memtest shows no errors, tried each stick individually, including while in safe mode and the crashes still occur while using prime 95. I attempted a stress test - https://www.reddit.com/r/techsupport/wiki/hwinfo_logging
This test lasted about 1 minute before crashing.
Given that it's crashing while in safe mode I'm assuming this is a hardware issue.
I've ensured that all drivers are up to date and that I'm using the most up to date version of my BIOS. All BIOS settings are set to default. I did use the Gigabyte easytune program to bump my clock speeds up to 4.8ghz temporarily but ended up going back to stock and removing all unnecessary software.
System specs - http://speccy.piriform.com/results/PvULuupKprLWDp4HXB07HHQ
Below is a mini dump from my most recent crash. The WHEA error pointing to Genuine Intel makes me think this is CPU related.
Any help would be appreciated.
Microsoft (R) Windows Debugger Version 10.0.17763.1 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Kyle's PC\Desktop\022219-7453-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 17763 MP (6 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Machine Name:
Kernel base = 0xfffff800`59c03000 PsLoadedModuleList = 0xfffff800`5a01ead0
Debug session time: Fri Feb 22 06:38:41.313 2019 (UTC - 5:00)
System Uptime: 0 days 0:00:03.016
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
*            Bugcheck Analysis                  *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {7, ffffb281330ea038, 0, 0}
Probably caused by : GenuineIntel
Followup:   MachineOwner
1: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000007, BOOT Error
Arg2: ffffb281330ea038, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10.0.17763.316 (WinBuild.160101.0800)
DUMP_TYPE: 2
BUGCHECK_P1: 7
BUGCHECK_P2: ffffb281330ea038
BUGCHECK_P3: 0
BUGCHECK_P4: 0
BUGCHECK_STR: 0x124_GenuineIntel
CPU_COUNT: 6
CPU_MHZ: e70
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 9e
CPU_STEPPING: c
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
ANALYSIS_SESSION_HOST: DESKTOP-EKVHL8C
ANALYSIS_SESSION_TIME: 02-22-2019 19:46:17.0004
ANALYSIS_VERSION: 10.0.17763.1 amd64fre
STACK_TEXT:
fffff68f`15bf84a0 fffff800`5a181a29 : ffffb281`2a151080 ffffb281`330ea010 fffff800`5a00a600 fffff800`00000000 : nt!WheapCreateLiveTriageDump+0x7b
fffff68f`15bf89d0 fffff800`59f21d78 : ffffb281`330ea010 fffff800`59c63811 00000000`00000000 ffffd50c`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x2d
fffff68f`15bf8a00 fffff800`59f22a8b : fffff800`5a00a5a0 fffff800`5a00a600 ffffb281`2abd8ee8 ffffb281`2a083840 : nt!WheapProcessWorkQueueItem+0x48
fffff68f`15bf8a40 fffff800`59cb71ea : ffffb281`2a0aacf0 ffffb281`2a151080 ffffb281`2abd8e00 ffffb281`00000000 : nt!WheapWorkQueueWorkerRoutine+0x2b
fffff68f`15bf8a70 fffff800`59c89bc5 : ffffb281`2a151080 ffffb281`2a0811c0 ffffb281`2a151080 00000000`00000000 : nt!ExpWorkerThread+0x16a
fffff68f`15bf8b10 fffff800`59dbd89c : ffff9d80`18024180 ffffb281`2a151080 fffff800`59c89b70 00000000`00000000 : nt!PspSystemThreadStartup+0x55
fffff68f`15bf8b60 00000000`00000000 : fffff68f`15bf9000 fffff68f`15bf2000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x1c
THREAD_SHA1_HASH_MOD_FUNC: 26acd050bd9f055d0a04825d57b9e0e6be9c1a07
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 2d7687bc4d9a24dd51c507635bc4ce8aa00fde94
THREAD_SHA1_HASH_MOD: 30a3e915496deaace47137d5b90c3ecc03746bf6
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel
DEBUG_FLR_IMAGE_TIMESTAMP: 0
STACK_COMMAND: .thread ; .cxr ; kb
FAILURE_BUCKET_ID: 0x124_GenuineIntel__UNKNOWN_PRV
PRIMARY_PROBLEM_CLASS: 0x124_GenuineIntel__UNKNOWN_PRV
TARGET_TIME: 2019-02-22T11:38:41.000Z
OSBUILD: 17763
OSSERVICEPACK: 316
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 784
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS Personal
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: unknown_date
BUILDDATESTAMP_STR: 160101.0800
BUILDLAB_STR: WinBuild
BUILDOSVER_STR: 10.0.17763.316
ANALYSIS_SESSION_ELAPSED_TIME: 3c7
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x124_genuineintel__unknown_prv
FAILURE_ID_HASH: {a7406f97-70d3-5fd4-2647-1fafa47ede59}
0 Compliments
5 Réponses
AlHill
Super utilisateur
5 626 Visites
I would try DIFFERENT memory, and a different power supply.
Doc
0 Compliments
KAitk1
Débutant
5 626 Visites
Unfortunately I don't have different memory or a power supply. But the more I think the power supply would make sense. I can use the computer if not stressed without much issue but as soon as it's under load it crashes. It's a semi module power supply, is it possible the PSU is fine but the cables need to be re-attached? Or with something like a bad power supply it's more to do with the internal components?
0 Compliments
KAitk1
Débutant
5 626 Visites
Maybe if someone could be so kind to review - https://drive.google.com/file/d/13q0w-SxTDg2G5F0v7zQbccJexC_C7_L4/view
Within is a CSV file with the crash details on it. I had someone look that has basic info and they also said the PSU was undervolting and throttling my GPU.
0 Compliments
David_V_Intel
Employé
5 626 Visites
Hello KAitk1, Thank you for posting on the Intel ® communities. I am following up with your case and would like to know if you still need help. If you need more assistance do not hesitate to reply. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
0 Compliments
KAitk1
Débutant
5 626 Visites
Hi David,
You can close this thank you.
I ended up putting in a RMA request for a new CPU. New CPU's were unavailable so I was asked to mail mine back and a refund would be granted. Still waiting for the refund but have purchased a replacement which has resolved all of my problems.
0 Compliments
Répondre
