Processors
14647 Discussions
Overheating i5-4690k: Support not working and I need to RMA
AMatt4
My i5-4690k CPU runs very hot under load and gaming. Core temperatures different from each other over 30c, ex. core 0 runs at 99c and thermal throttles and core 3 runs under 70c (see picture 1). CPU is running at stock BIOS settings and is not overclocked. Tests were run with Prime95 for 15minutes. IBT skyrocketed core 0 to 100c in a second.
Things that I have tried:
I'm thinking that thermal paste between cores and the IHS is not correctly installed and heat won't transfer to heat sink. Warranty until 09/2018. I have checked FTO and ATPO.
About attached pictures: Temperature monitoring by HWiNFO64, temps from left to right 1:current 2:min 3:max 4:avarage
AMatt4
No answer from Intel?
Hi happoman,
Each Core can run in a different speed and consequently each Core has its own temperature. We need to focus in the overall temperature. Several games are not prepared to work with multiple Cores, so they just use 1 Core.
Now, I suggest you to make this last test before requesting a processor replacement through our contact center support.
http://www.intel.com/content/www/us/en/support/contact-support.html http://www.intel.com/content/www/us/en/support/contact-support.html
Go to BIOS, make sure Processor Base Frequency is set to 3.5GHz and RAM is running at DDR3-1333/1600 1.5v or DDR3L-1333/1600 @ 1.35V.
Save BIOS changes, go to Windows and run our Intel® Processor Diagnostic Tool alone, close any other application. It is a stress tool.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Mike C
