Processors
14759 Discussions
P4 BIOS CONFIG ?
hi dear everyone
after the some hardware changes in my pc also included my bios battery i tuned on the pc and i having couple of os hang and reboot
then i look inside the pc and i touch the CPU's cooler the thing were maded by metal was too hot i thought it was not normal and took a look to bios
and all the settings at bios are turned to default then i set some basic settings but
i have no idea what sould i do for cpu configuration. motherboard have an award bios and using "P4 2.6 ghz" CPU
and there are some options like that at the bios
CPU speed [Manuel] or [2667]Mhz
CPU Frequency multiple [1x.........]
CPU External Frequancy [100.......]
there was a many options like that but they have two alternative like auto or digits and all of that set to auto because there was written "recommended" by bios
but that options have no auto choice and there was some digits and manuel option instead of this and i dont know what they should set to.
any suggestion or where can i find
for a maximum performance and also safely using without any damage on system so im a poor man i have not so much money to lose
thanks a lot ......
Hi Mtrcurse
You mention that you done some hardware changes....what hardware changes do you refer to? Why did you do that hardware changes?
What motherboard do you have?
Span1shUk
i have an ASUS P4XP-X mother board i just changed bios battery and connected a another harddrive upon my current one
and thats connected to mother board with an 80 pin IDE cable and both of thats connected with same cable
thats all
You should be able to load the optimised defaults and that will set things correctly.
If you not changed the CPU, set any setting in the BIOS incorrectly, or accidentally shifted the heat sink. Then the heat that you feel should be the normal heat output from the processor.
yes it could help but i dont want to resolve this prob with trial and error method
im worry about to give a damage to cpu during this time
and more than i feeling i need to certain some knowledge about that digits meaning
i wondering is there a guide or manuel exist contains recommendation about the bios setting of a P4 2.6 ghz procoessor for efficiently and safely use
thanks for your interest
The optimised defaults option will set all the BIOS setting to the most suitable setting settings, for efficiency and saftey.
understood sir
thanks for your helps
