On the way to upgrade my Asus P5L-MX mobo I bought a sh Intel Pentium E6700, the one with 3.2 Ghz, 2 MB L2.
I could not find the Dual Core 2 E6700, 2.66 Ghz, 4 MB L2, the one Asus reccomends.
I took the risk to buy the first one as I found on Game Debate that the P E6700 might work also..
I managed to boot the system with the P E6700, but the BIOS does not recognise it correctly..
I fixed manually the CPU frecq, FSB and DDR2.. to the best I could..
At the beginning I received at each boot "CPU ucode incorrect. Press F1 to resume" ... bothering honestly..
Now, from BIOS, I managed to get rid of the "Press F1 to resume" command, so I remained only with the POST message "CPU ucode error", which is not so bothering...
Manually fixing the CPU, FSB and RAM frequency I managed to stabilise the system at a performance 4 times better than the one of my previous P4 3 GHz processor.. So the risk I took worth it, as we talk small money.. sh parts..
There is still an issue which I didn't solve and I need help...
The Shut Down command does not close the Win XP completely.. The system blocks after "Saving current settings".. I have to close it from the Power button..
Any ideas?
Thank you
Thanks for joining the Processor community.
This is the list of compatible processors for your motherboard model Asus P5L-MX
http://support.asus.com/cpusupport/list.aspx?SLanguage=en&m=P5L-MX&p=1 ASUSTeK Computer Inc. -Support- CPU Support P5L-MX
I recommend checking with Asus for possible BIOS and compatibility issues.
http://www.asus.com/support/ ASUSTeK Computer Inc. -Support-
Allan.
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
