Processors
13887 Discussions
Processor DMP File Help - Blue screen
Brittney
My issues started 2 months ago various blue screens, and then it would be black screen with a messed up view of my graphics. It wasnt gpu etc. Found out my cooling was going out fixed that and its been ok. But its started blue screen again. Below is my DMP file for the most recent blue screen. PCU has tested fine ive had it tested by many different computer places ive taken it. Any help?
Microsoft (R) Windows Debugger Version 10.0.25200.1003 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Owner\Documents\012623-5062-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 19041 MP (20 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Edition build lab: 19041.1.amd64fre.vb_release.191206-1406
Machine Name:
Kernel base = 0xfffff803`4c800000 PsLoadedModuleList = 0xfffff803`4d42a2d0
Debug session time: Thu Jan 26 08:07:15.191 2023 (UTC - 6:00)
System Uptime: 0 days 0:02:37.852
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff803`4cbfa1d0 48894c2408      mov     qword ptr [rsp+8],rcx ss:ffffc380`3d946910=0000000000000124
15: kd> !analyze -v
*                        Bugcheck Analysis                                    *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffdc0fb5464028, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 00000000b2000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000030005, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: hal!_WHEA_PROCESSOR_GENERIC_ERROR_SECTION                ***
***    work.                                                          ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 2890
    Key  : Analysis.DebugAnalysisManager
    Value: Create
    Key  : Analysis.Elapsed.mSec
    Value: 12790
    Key  : Analysis.IO.Other.Mb
    Value: 16
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 30
    Key  : Analysis.Init.CPU.mSec
    Value: 609
    Key  : Analysis.Init.Elapsed.mSec
    Value: 47033
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 98
    Key  : Bugcheck.Code.DumpHeader
    Value: 0x124
    Key  : Bugcheck.Code.Register
    Value: 0x124
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Timestamp
    Value: 2019-12-06T14:06:00Z
    Key  : WER.OS.Version
    Value: 10.0.19041.1
FILE_IN_CAB:  012623-5062-01.dmp
BUGCHECK_CODE:  124
BUGCHECK_P1: 0
BUGCHECK_P2: ffffdc0fb5464028
BUGCHECK_P3: b2000000
BUGCHECK_P4: 30005
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  RazerInstaller.exe
STACK_TEXT:
ffffc380`3d946908 fffff803`4ccb697a     : 00000000`00000124 00000000`00000000 ffffdc0f`b5464028 00000000`b2000000 : nt!KeBugCheckEx
ffffc380`3d946910 fffff803`4b4815b0     : 00000000`00000000 ffffdc0f`b5464028 ffffdc0f`ad1db7d0 ffffdc0f`b5464028 : nt!HalBugCheckSystem+0xca
ffffc380`3d946950 fffff803`4cdb8b9e     : 00000000`00000000 ffffc380`3d9469f9 ffffdc0f`b5464028 ffffdc0f`ad1db7d0 : PSHED!PshedBugCheckSystem+0x10
ffffc380`3d946980 fffff803`4ccb82a1     : ffffdc0f`b54ab900 ffffdc0f`b54ab900 ffffdc0f`ad1db820 ffffdc0f`ad1db7d0 : nt!WheaReportHwError+0x46e
ffffc380`3d946a60 fffff803`4ccb8613     : 00000000`0000000f ffffdc0f`ad1db820 ffffdc0f`ad1db7d0 00000000`0000000f : nt!HalpMcaReportError+0xb1
ffffc380`3d946bd0 fffff803`4ccb84f0     : ffffdc0f`ad11b448 00000783`00000001 00000000`00000000 00000060`00000010 : nt!HalpMceHandlerCore+0xef
ffffc380`3d946c20 fffff803`4ccb8741     : 00000000`00000014 00000000`00000001 00000000`00000000 00000000`00000000 : nt!HalpMceHandler+0xe0
ffffc380`3d946c60 fffff803`4ccb79ab     : 00000000`00000000 00000000`00000000 ffffc380`3d946ef0 00010018`0000004c : nt!HalpMceHandlerWithRendezvous+0xc9
ffffc380`3d946c90 fffff803`4ccba1f5     : ffffdc0f`ad11b448 01d92606`5712dec9 01d92606`5712dec9 00000000`00000000 : nt!HalpHandleMachineCheck+0x5f
ffffc380`3d946cc0 fffff803`4cd0fc99     : 002d0068`007a0005 00000000`00570054 000001a8`00000090 00010000`00180400 : nt!HalHandleMcheck+0x35
ffffc380`3d946cf0 fffff803`4cc0adba     : 00000001`00000030 00000001`00001000 00000178`00000010 00000000`00000178 : nt!KiHandleMcheck+0x9
ffffc380`3d946d20 fffff803`4cc0aa77     : 00000000`00000000 00000000`00000000 00000000`00000003 00000000`00000000 : nt!KxMcheckAbort+0x7a
ffffc380`3d946e60 00007ffb`de46156b     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x277
00000000`00aeb820 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffb`de46156b
MODULE_NAME: GenuineIntel
IMAGE_NAME:  GenuineIntel.sys
STACK_COMMAND:  .cxr; .ecxr ; kb
FAILURE_BUCKET_ID:  0x124_0_GenuineIntel_PROCESSOR__UNKNOWN_IMAGE_GenuineIntel.sys
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {5371cb52-c3d9-558e-47d4-d31c09567ca2}
Followup:     MachineOwner
15: kd> nt!_WHEA_ERROR_RECORD structure
        ^ Syntax error in 'nt!_WHEA_ERROR_RECORD structure'
15: kd> !errrec ffffdc0fb5464028
Common Platform Error Record @ ffffdc0fb5464028
Record Id     : 01d9318f20757d9f
Severity      : Fatal (1)
Length        : 872
Creator       : Microsoft
Notify Type   : Machine Check Exception
Timestamp     : 1/26/2023 14:07:15 (UTC)
Flags         : 0x00000000
Section 0     : Processor Generic
Descriptor    @ ffffdc0fb54640a8
Section       @ ffffdc0fb5464180
Offset        : 344
Length        : 192
Flags         : 0x00000001 Primary
Severity      : Fatal
***    work.                                                          ***
***    work.                                                          ***
No valid data fields are present.
Section 1     : x86/x64 Processor Specific
Descriptor    @ ffffdc0fb54640f0
Section       @ ffffdc0fb5464240
Offset        : 536
Length        : 64
Flags         : 0x00000000
Severity      : Fatal
***    work.                                                          ***
***    Type referenced: hal!_WHEA_XPF_PROCESSOR_ERROR_SECTION                ***
***    work.                                                          ***
Section 2     : x86/x64 MCA
Descriptor    @ ffffdc0fb5464138
Section       @ ffffdc0fb5464280
Offset        : 600
Length        : 272
Flags         : 0x00000000
Severity      : Fatal
***    work.                                                          ***
***    Type referenced: hal!_WHEA_XPF_MCA_SECTION                     ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Error         : Unknown (Proc 0 Bank 0)
  Status      : 0x0000000000000000
