Buenas, tengo dudas con respecto a mi procesador, tengo una laptop que tiene el siguiente CPU: Intel Core i5 - 9300H 2.40 Ghz y ando buscando hace muchos meses alguna aplicación o dentro del equipo algo que me limite el uso de la CPU y la temperatura, y resulta ser que configure algo en el apartado de batería que solo se utilice el 80% pero igualmente suelo jugar demasiado por ejemplo: Tengo el CoD WWII y me andaba consumiendo un 70% de CPU y 97 grados! y cuando puse esto ahora esta 56% de uso y 50 grados considerando que los otros componentes también bajaron como la RAM (antes: 10 GB mi pc total, luego: 8 GB en total), mi pregunta es....lo que hice ¿Esta bien? no "quemara" de alguna forma la CPU o la vida útil de los ventiladores... Gracias si alguien puede responder.
Hello GCorn1,
Thank you for posting your question on this Intel® Community.
When the processor is operating at or near its maximum frequency, it's possible for the temperature to climb very rapidly and quickly reach its maximum temperature. In sustained workloads, it's possible the processor will operate at or near its maximum temperature limit.
Being at maximum temperature while running a workload isn't necessarily cause for concern. Intel processors constantly monitor their temperature and can very rapidly adjust their frequency and power consumption to prevent overheating and damage.
Now, customizing the processor power management options in Windows can help you balance the performance and energy efficiency, and they should not have a negative impact on the processor. However, our recommendation is that you contact your computer manufacturer to make sure the parameters in the OS and BIOS are configured correctly based on the cooling solution your computer is using and components installed (e.g. fans)
Note: Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded on this Intel® Community.
Wanner G.
Hello GCorn1,
If you need further assistance, please let us know. We will be glad to help you.
Wanner G.
Hello GCorn1,
We have not heard back from you, so we will close this thread. If you need further assistance, please start a new thread, we will be glad to help you.
Wanner G.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
