Hello again, Processors Forum. I'm writing this as a new question so that it didn't get lost in my previous thread.
When the LE80536LC0172M-SL89N (/products/27603/Intel-Pentium-M-Processor-LV-738-2M-Cache-1_40-GHz-400-MHz-FSB Intel® Pentium® M Processor LV 738 (2M Cache, 1.40 GHz, 400 MHz FSB) was obsoleted and replaced by the LE80536LC0172M-SLJ8U, as part of a RoHS upgrade, the CPU stepping code changed from C0 to C1. Can you please disclose what changed in the CPU die with this stepping code change? Is there a report you can share showing the exact same functionality between the SL89N and the SLJ8U versions of this CPU? I work in a medical device company where every component change has to be documented and understood, so as much information as you can disclose would be most helpful to me.
Thank you,
Matt
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
