Processors
14865 Discussions
What Changed in Stepping Code Change C0 → C1 for LE80536LC0172M-SL89N → LE80536LC0172M-SLJ8U?
Hello again, Processors Forum. I'm writing this as a new question so that it didn't get lost in my previous thread.
When the LE80536LC0172M-SL89N (/products/27603/Intel-Pentium-M-Processor-LV-738-2M-Cache-1_40-GHz-400-MHz-FSB Intel® Pentium® M Processor LV 738 (2M Cache, 1.40 GHz, 400 MHz FSB) was obsoleted and replaced by the LE80536LC0172M-SLJ8U, as part of a RoHS upgrade, the CPU stepping code changed from C0 to C1. Can you please disclose what changed in the CPU die with this stepping code change? Is there a report you can share showing the exact same functionality between the SL89N and the SLJ8U versions of this CPU? I work in a medical device company where every component change has to be documented and understood, so as much information as you can disclose would be most helpful to me.
Thank you,
Matt
Silvia_L_Intel1
please check the post on the following link /thread/39825 http://communities.intel.com/thread/39825
Silvia_L_Intel1
