Processors
14711 Discussions
Why is turbo boost causing windows 10 to crash? i7 7700k
BRive2
Temps mostly below 70'C, Everything in bios is at default...Whea Uncorrectable Error BSOD (which is hardware related) while stress testing with turbo boost enabled in bios, at one point it wouldn't even boot to desktop until I disabled turbo boost.
System specs:
MB: Asus ROG Maximus IX Z270 Code
CPU: Kabylake i7-7700k
CPU Cooler: Corsair H100i V2
RAM: G.SKILL TRIDENT Z CL 14-14-14-34 1.35v 3000mhz (XMP not enabled nor timings set)
PSU: EVGA supernova G3 1000w
GPU: Asus strix gtx1080 A8G
Drive:Crucial MX300 525gb SSD
OS: Windows 10 Home
If any more information is needed it will be provided.
Thanks Guys
CCris2
New Contributor II
Hi Bryant_R ,
Try to set CPU Core Ratio to Sync All Cores and 1-Core Ratio Limit to 45 and see if this works better.
If you still want to use turbo boost function, I suggest to verify the CPU voltage when turbo boost is enabled, some Asus mainboards don't set the right voltage.
There is a CPU Core/Cache Voltage option in bios called Adaptive mode that lets you modify the voltage for turbo mode.
Have a nice day.
Hello Bryant_R,
Try with a BIOS update; you can download the latest version for your motherboard at the following link:
https://www.asus.com/Motherboards/ROG-MAXIMUS-IX-CODE/HelpDesk_CPU/ https://www.asus.com/Motherboards/ROG-MAXIMUS-IX-CODE/HelpDesk_CPU/
You can also contact ASUS for BIOS update instructions or following their BIOS Flashing Method.
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Make sure the BIOS is running at default settings and your ram running at 2133 or 2400 MHz
Ivan.
BRive2
oh the ram is set to auto, it's rated at 3000mhz but everytime I enable xmp and do some testing the pc crashes.
BRive2
Thanks guys after a bios update it stabilized for real world use, but I'm still getting the bsod during gaming or while running intel burn test on maximum...anyway I can troubleshoot the problem? I've done memtest 86 for 16 passes no errors, and prime 95 for 3 hours.
any feedback is appreciated still new to most of this.
In this case, I suggest having the RAM running at 2133 or 2400 MHz, 3000mhz is overclocking and even though the processor is unlocked and you can overclock it that will be out of the processor specifications and I'm sure that is causing BSOD and instability problems. If you want to use you system without this problem I recommend disabling XMP mode and ran it at 2133 or 2400 MHz.
Sincerely,
Ivan.
BRive2
Thanks Ivan, I've made sure the ram is running at 2133, sadly the error keeps occurring. I've replaced the PSU, MOTHERBOARD, GPU, and RAM I'm Stumped I can't seem to pass IBT or play longer than 30 mins. I bought another CPU and should be able to get it running hopefully by the end of the week. If the error keeps happening I will let you know.
Sorry for the trouble.
Thank you for the information and keep us posted about the result with the new processor, if you still have problems with the old processor, I suggest you to http://www.intel.com/content/www/us/en/support/contact-support.html# @14 Contact Support and request and RMA for that processor.
Best wishes,
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
