Processors
16007 Discussions
XTU Process Profile executable name with single quote
telefunk
Tried pairing a profile with an executable that contains a single quote (i.e ...er's.exe).  This causes an unhandled exception when loading the GUI.
A snippet from the GUI log file:
2021/12/29-11:09:13.0543|!CRI] Unhandled exception on dispatcher occurred
2021/12/29-11:09:13.0543|!CRI] System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> Microsoft.Practices.Unity.ResolutionFailedException: Resolution of the dependency failed, type = "PerfTune.Managers.ITelemetryMessageBox", name = "(none)".
Exception occurred while: Calling constructor PerfTune.Views.Modals.TelemetryMessageBox().
Exception is: ResolutionFailedException - Resolution of the dependency failed, type = "PerfTune.ViewModels.TelemetryMessageBoxViewModel", name = "(none)".
Exception occurred while: Calling constructor PerfTune.ViewModels.TelemetryMessageBoxViewModel().
Exception is: ResolutionFailedException - Resolution of the dependency failed, type = "PerfTune.ViewModels.SettingsViewModel", name = "(none)".
Exception occurred while: Calling constructor PerfTune.Managers.MidnightCanyonManager(IronCity.Common.IRegistryAbstraction , PerfTune.Managers.IProfileManager , PerfTune.Interfaces.IManualTuningManager , PerfTune.Managers.IStateManager ).
Exception is: ManagementException - Unparsable query.
telefunk
The executable also has a space in the name.  So like... Executable's Name.exe.
Alberto_R_Intel
telefunk, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
What is the model of the Intel® processor?
If this is a laptop, what is the model of it?
Is this a new computer?
When did you purchase it?
Was Intel® XTU working fine before when trying pairing a profile with an executable that contains a single quote on this same machine?
When did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
telefunk
  • Gigabyte laptop MB
  • i7-11800H
  • Gigabyte Auros 15P XD
  • 6 months
  • July 2020
  • XTU worked fine before pairing and after by manually removing pairing from the config file (ProcessProfiles.xml).  Was able to reproduce by re-adding pairing.
  • Issue started when attempting to restart XTU (GUI).  Was able to save it and XTU continued to run but failed to re-open after exiting.
  • No changes.
  • Windows 10 21H2 (19044.1415)
  • At home.
Intel XTU 7.6.0.37
Alberto_R_Intel
Hello telefunk, Thank you very much for providing that information.
In reference to this case, just to let you know, the Intel® Extreme Tuning Utility (XTU) is fully compatible only with unlocked and extreme Intel® processors, those are the ones where the model ends with a K or an X as you can confirm in the link below. So any discrepancies or instabilities while using a different kind of processor will be expected for the tool. Please take a look at the list of Intel® supported processors for the Intel® XTU application:
https://www.intel.com/content/www/us/en/download/17881/intel-extreme-tuning-utility-intel-xtu.html?wapkw=intel%20extreme%20tuning%20utility%20intel%20xtu
Albert R.
