Does anyone know if the X3380 has a unlocked multiplier ??
This option is not available on your processor, since this option is available only for extreme series processors, you can find more information on your processor specifications here:
http://ark.intel.com/Product.aspx?id=41094&code=X3380 http://ark.intel.com/Product.aspx?id=41094&code=X3380
Well Sergio I installed the X3380 on my DX48BT2 all went fine working like a champ , I'm going to run it for a day or two , Before I start seeing just what I can OC it to., But this CPU will work on a DX48BT2. And works well so Intel needs to change their spec sheet. because according to your chat support , they say that you can't use a X3380 with a DX48BT2, I was told NO Match???
Hello;
Indeed the X3380 has not been tested on your DX48BT2 desktop board, that is why the chat agent explained you that is not compatible, you can confirm this information here:
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dx48bt2
Remember that using a non compatible processor on a desktop board may short the life of both the desktop board and the processor
Machine runs perfect . Normal temps , very good performance. No problems.
That chart was posted before the X3380 was Mfg. It's OLD News.
![](/skins/images/FCBE28625AAD2D8AF3EB3F393BF39703/responsive_peak/images/icon_anonymous_message.png)
