can an E-7 8837 be upgraded using E-7 8860 ES when they both have A2 stepping ?
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
Hi adlihajarat,
If you are comparing processors of the same generation, the answer is yes. Intel® Xeon® Processor E7-8860 and Intel® Xeon® Processor E7-8837 belong to the same family, same socket. This is possible if you are only using 1 processor in your Server board. It is always necessary to keep using the same processor model.
Now if you want to upgrade the Xeon® Processor E7-8837 with a Xeon® Processor E7-8860 v3, this is not possible. The newest version has socket type 2011, requires more energy and supports DDR4 memories.
Intel® Xeon® Processor E7-8860 v3 (40M Cache, 2.20 GHz)
http://ark.intel.com/products/84680/Intel-Xeon-Processor-E7-8860-v3-40M-Cache-2_20-GHz Intel® Xeon® Processor E7-8860 v3 (40M Cache, 2.20 GHz) Specifications
Comparison chart (E7-8860 - E7-8837)
http://ark.intel.com/compare/53572,53576 ARK | Compare Intel® Products
Mike C
