Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
Hello. Ever since, I bought my processor, I am experiencing this problem where after half or so hour of moderate to heavy load, my system would just freeze and I have to do a hard reset to get it back working. Initially, I thought it might be due to heating issue, so I bought an AIO which doesn't allow my cpu to go even above 50 even while gaming on max settings. However the issue still persists.
Recently, I tried to stress test my CPU using cinebench. On multicore test, it finishes the 10 min mark most of the time, sometimes it would freeze and I have to hard reset again. But whenever I try to run single core stress test, it always freezes the whole system within 2-3 minutes. I tried checking individual cores by setting the affinity in task manager to just use efficient cores and it doesn't crash when using them. But whenever I am using performance cores, the crash is always there. I am not sure what's going on... can anyone pls help? The system on idle runs smoothly for around 2 hours or so and then it would randomly freeze again and I have to repeat the same process...
Please ask if you require any log files for further assessment..
Specs:
i5 14500
ASUS prime b660M-D4
1x 16GB ram 3200mhz
Zotac Nvidia GTX 1070Ti
Hello Cynicalcare,
Can you try running Intel® Processor Diagnostic Tool for us to check if the processor will pass the test?
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html`
Michael L.
Hello Mike.
I ran the test and it passed it. I have attached the results below.
Hello Cynicalcare,
Thank you for the quick reply.
Upon checking the details that you provided, you are not using a "K" processor and it passed all the test in the Processor Diagnostic tool. Let me provide gather the following details for us to proceed.
Michael L.
Hello Cynicalcare,
Thank you for the update.
You are correct, at this point it is hard to tell between the processor and the board.
That is why we recommend to perform swap test.
Michael L.
Hello Cynicalcare,
Michael L.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
For more complete information about compiler optimizations, see our Optimization Notice.
