Processors
14957 Discussions
high core count for future CPU suggestion
legolasyiu
Hello Intel community,
I always have a dream of creating processors, but for now, I will just add my 2 cents here.
I research and examine the core count for AMD and Intel. It appears there is some improvement for Intel for core count. If Intel can integrate 28 cores, why not integrated double/triple to 84 cores or more by shrinking the process or other technology. Another way is to integrated cores (80) using Foveros - hybrid CPU technologies, perhaps, putting 2 cores stacked or 2 cores by circuit. I see there might be slower frequencies with increasing cores but that is a trade-off with a higher core count. It might need a special turbo level at some stages in the processor. It appears there is a lower core count with high frequencies for high-performance servers processes. That is normal. Hopefully, that helps with Intel.
JoseH_Intel
Hello legolasyiu,
Thank you for joining the community
We appreciate your suggestion and will router appropriately to our research and design team.
Just as a background info there has been Xeon processors designed with higher core counts like the Xeon Phi 7295 series with up to 72 cores running at a frequency of 1.6 GHz.
Intel® Xeon Phi™ Processor 7295 (16GB, 1.5 GHz, 72 Core) Product Specifications
In case you have further comments just let us know.
Jose A.
legolasyiu
any feedback or discussion?
AlHill
No, no discussion.  This is a technical support forum.
[Windows 11 is the new Vista]
AndrewG_Intel
Hello @legolasyiu
We understand that you are providing suggestions for future CPU developments. Is this correct?
In order to determine the proper channel of support, could you please confirm if this is general feedback referring to processors for "end-users" (e.g.: Intel® Core™/Pentium®/Celeron® Processors) or is this regarding Intel® Server Processors/Server Platforms (e.g.: Intel® Xeon® Processors)?
Andrew G.
legolasyiu
Hello Andrew G,
Yes, I am providing suggestions for future CPU developments.
It is regarding Intel Server processors/Server Platform.
AndrewG_Intel
Hello legolasyiu
Thank you very much for your response and for the clarification.
We are routing this to our Server Support team in order to provide you with the proper information. The team may be providing more details within 1-2 business days.
Andrew G.
JoseH_Intel
Hello legolasyiu,
Jose A.
legolasyiu
Hello team,
Thanks for the information.
Intel Xeon Phil Processor is EOL? it was out at 2017.
If Intel had the expertise to design Xeon Phi 7295. You can use a similar layout for Xeon and increase frequency from 1.6Ghz to a much higher frequency with 7nm/10nm node technology and you can get the cores count and speed needed to compete with others vendors.
