i need help to do oc in my gpu, im watching some tutorial but the version of my xtu is new and don't see thats options :C
Hello Isaias1995,
I just wanted to let you know that Intel does not provide assistance for overclocking, so in this case the best thing is to wait for another community member to post similar experience or get more feedback on other forums. Maybe you could try with http://www.overclockers.com/forums/ Overclockers Forums or http://forums.extremeoverclocking.com/ EXTREME Overclocking Forums - Learn To Overclock Your PC Hardware.
Before visiting these sites, please bear in mind that altering PC clock or memory frequency and /or voltage may reduce system stability and use life of the system, memory and processor; it causes the processor and other system components to fail; it causes reductions in system performance; it causes additional heat and other damage; and affects system data integrity. Intel assumes no responsibility that the memory, included if used with altered clock frequencies and / or voltages, will be fit for any particular purpose.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
