hello,
i have an intel i3 7100 on my pc i built about a week ago and my idle temp is 55c to 54c but when gaming
i get to 85c to 100c
i installed the cpu fan correctly and i have 3 fans on my case that came with it
any ideas?
my pc specs
gtx 1050ti
intel i3 7100 3.9
8 gb ram
msi b250m gaming micro
thank you for taking the time to read this.
Hello fawazsaad,
Thank you for contacting the Intel community.
Well, this processor can work without problem at 100°C (TJUNCTION 100°C), you can see here:
https://ark.intel.com/products/97455/Intel-Core-i3-7100-Processor-3M-Cache-3_90-GHz https://ark.intel.com/products/97455/Intel-Core-i3-7100-Processor-3M-Cache-3_90-GHz
This is normal temperature for this processor; however, if you want your system to run at lower temperature you can try updating the processor BIOS, reapplying thermal paste, to update your BIOS you will to contact MSI for them to give instructions on BIOS update, you can try downloading and follow BIOS update instructions here:
https://www.msi.com/Motherboard/B250M-GAMING-PRO.html# productFeature-section https://www.msi.com/Motherboard/B250M-GAMING-PRO.html# productFeature-section
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Please bear in mind that if your system runs at a temperature that the processor doesn't support to prevent damage to components, the computer shuts down or reboots if it senses an overheating issue. The system might reboot every few minutes until the problem is resolved. This often occurs if your system CPU is over-clocked (sped up past the recommended speed limits). The BIOS usually reports if a thermal event has occurred.
I hope this can help.
Ivan U.
Hello fawazsaad,
Ivan U.
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
